skymole
Hi all.
Looking for a bit of advice re adhesive - firstly I'll probably narrow it down to Mapei because we have an account with a Mapei disti and can get good prices - unless there are any overiding factors.
The project is a bathroom / wetroom.
Suspended floor with ply, wediboard, UFH and Mapei Fiberplan SLC
Shower area is Wedi tray with Wediboard walls.
Rest of room plastered.
I'm looking for recommendation for adhesive for the following situations.
1. The main floor is to be tiled with 600 x 400 granite (need to deal with upto 5mm low areas in the SLC)
2. Shower area (walls and tray) to be tiled with 300 x 300 marble mosaic with 23mm tessera.
3. Floor to ceiling basin splashback - there will be a continuation of tile skirtings to form this splashback. The tiles will be the same as the floor tiles (600 x 400 x 15) flamed granite.
Also with regard to 3. above what would ppl recommend - these are obviously much larger tiles than one should apply to plastered walls - is there another solution other than hacking back to the brick and applying a board or render.
Any advice greatly appreciated
Sky
Sky
