Discuss Which adhesives to use? in the Canada Tile Advice area at TilersForums.com.
alexma
Hi Everyone. This is my first post... I am tiling a bathroom, walls and floor. Just been re plasterboarded (D & D) & primed with SBR. Shower area boarded with Showerwall. My tiles are ceramic 400 x 250 x 10mm. I've been reading the posts & am worried about the 'weight issue' on plasterboard. Do I have problems here? Which adhesive do I use? The room is only 6'2" x 6'2". The floor is newly laid 18mm ply well secured, with extra noggins and I'm using 305 x305 x10mm granite tiles. Do I need to prime the floor, and which adhesive to use. Many thanks in advance Alex
Hi, welcome.
DIY??
By the sound of it the walls will be ok, presume 'showerwall' is some sort of aquaboard taped/tanked etc...
For the floor I'd be overboarding the ply with something a bit more suitable.
I'd be using a slow-setting flexible adhesive on the walls and Granirapid, or a similar 2 part for the floor.
As for priming, the adhesive manufacturers instructions will say
Plasterboard takes about 24kg per m2. If you are unsure about the weight you could always mechanically fix the plaster board as well. ( screw through the plasterboard where the board has been d&d use washers with screws)
Ply on the floor will need primed, but consider using tile backer board on top of the ply.
Adhesive- Single part flex for the walls and a ultra-flex for the floor.
widler
1,328
England
Set plus is a slow set mate, really similar to tilemaster standard.
See why call it set plus ! Thats just confusing .
I bet its that webber i used,it took forever to set. Infact is it a yellow and black bag.
Yes good stuff , im using tilemaster standard at the mo, good stuff too
I
Ian
Yeah it confused me when I first saw it. The weber rapid sets have the word rapid in the title. I'm used to it now I've been using their gear for a year or so.
Reply to Which adhesives to use? in the Canada Tile Advice area at TilersForums.com
    • Optimistic
My tiles are moving after 3 days of been layed on Cement floor. I used MapeGrip D2. just seen a...
Which tile adhesive should I use for 60x60cm porcelain floor tiles? The floor is concrete that...
I have recently laid around 30msq of porcelain floor tiles in our kitchen. The tiles have been...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
