Discuss Which grout for internal limestone slabs over UFH please? in the Canada Tile Advice area at TilersForums.com.
H
Huskeeter
Hi there very helpful people :)
I am looking for the best advice to grout the following. I'm a competent DIYer and this is in my own self-built outbuilding.
Size: 9 x 5m internal, heated office
Base: 70mm insulation, then DPM then reinforced concrete then UFH
UFH: Water-fed, closed system, then
Screed: with fibres, laid about 18 months ago
Tile bed: Sand-cement solid bed
Tiles: 21mm Bradstone limestone, varying sizes up to 1200x600, all laid about 12 months ago
Joints: varying between 7 and 20mm
Cleaned once, let dry for one month
Sealed twice with Mattstone limestone sealer 4 days ago
So now I'm hopefully ready to grout.
QUESTION: Must I use a flexible wide joint compound OR I have also been advised to use a fairly dry sand-cement mix, 4 parts to 1 part, wash off using very little water and then seal twice again?
Would find your advice and opinions incredibly helpful. Thank you. :thumbsup:
Reply to Which grout for internal limestone slabs over UFH please? in the Canada Tile Advice area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hello I am looking for the best way to joint Limestone paving after having sealed it. If I...
Peter Knight
Hello. I'd appreciate it if you guys could help me out here; I've been reading as many threads...
    Votes: 5 4.2%
    Votes: 11 9.2%
    Votes: 7 5.8%
    Votes: 33 27.5%
    Votes: 15 12.5%
    Votes: 31 25.8%
    Votes: 3 2.5%
    Votes: 2 1.7%
    Votes: 19 15.8%
    Votes: 18 15.0%
    Votes: 13 10.8%
    Votes: 6 5.0%
    Votes: 3 2.5%
    Votes: 2 1.7%
