Discuss Which is best plywood to tile on ? in the British & UK Tiling Forum area at TilersForums.com.
Aztectiler
Firstly make sure that hte floor is solid and deflection free.
An external WPB ply is the only ply to use.
Prime the ply on the underside and sides with an sbr primer prior to fitting and fix at no less than 200mm centers
Tile with a flexible adhesive and grout with a flexible grout as this will compensate for slight movement.
david campbell
Reply to Which is best plywood to tile on ? in the British & UK Tiling Forum area at TilersForums.com
    • Friendly
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
