Discuss Which is the better tiling method? in the British & UK Tiling Forum area at TilersForums.com.
missangorabunny
Hello. I'm wanting to get my hallway (9 square meters) tiled with sheeted victorian floor tiles. Currently the hall is just bare floorboards (it's a victorian conversion flat). I've received estimates from 2 tilers, each of whom seems to suggest a quite different method. One proposes to lay 6mm Hardi backer and fix the tiles to this. The other seems to be suggesting something more complicated - "put board [doesn't specify what kind of board] on floor, put waterproof ditra mat down, add selflevel, then fix tiles". Funnily enough, this is the significantly cheaper quote. I have no expertise at all, so would be interested to know if one method would be considered preferable over the other?
Ajax123
1,213
Lincolnshire
The fewer elements there are involved the fewer risks need to be managed. I would gothe hardibacker route but there is significant merit in lifting the floor Boards to check the subfloor for old age conditions, e.g. Worm, wet rot etc. This will also allow you to insulate between the joists and insert noggins to remove any bounce. You cant tile old victorian floors "on the cheap" if you want them to last.
No bounce and well fixed hardibacker removes the need for ditra. You only need levelling compound if the floor is not level.....the hardibacker will level things out as well.
Reply to Which is the better tiling method? in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm retiling the walls in the pictures which is a shower above a bath - one wall is stripped...
Hello everyone, new to the forum, nice to meet you. A tiler recommended to bring this question...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
We've got as far as stripping out the bathroom in our new (to us) bungalow dug up floor, laid...
Hi all I am new to the forums and looking to get my kitchen diner floor tiled which is approx...
11K
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
