Tiling concrete floor and UF heating
You were advised how to approach this and have ignored it and it’s failed.
Cost cutting is to blame I believe....
All of Harry’s advice was followed and I went through it with the tiler and insisted they do this despite them suggesting skipping some steps
I can assure you no corners being cut
Before the job started the builder was going to put down SLC which would have cost me £250 more and I already paid the builder to buy materials - but the tiler came and said the concrete floor was fine and he could prime the floor and lay the boards and self level after - I asked him to wait a day for the builder to self level but he insisted with his 20 years experience it was fine as is and maybe he was right
The step that was missed was the slc on the concrete floor at the insistence of the tiler
So please don’t blame my cost cutting as I actually went for one of the higher quotes and have specified all of the premium materials with no expense spared - for me quality is paramount !
I blame shoddy tradesmen claiming they know how to do the work but don’t and me having to do my research in advance due to the inconsistent and differing approaches offered by apparent ‘professionally qualified’ tradesmen
Anyway I have one of the other Tiler’s who initially quoted me to give another opinion and then will decide what to do
As it stands there are a few spots like this which as I said are isolated and with the tiles laid should resolve the problem so will see what the other Tiler says and decide what to do
I am probably being overly cautious and I am sure that this is Absolutely fine - was looking for some similar stories or experiences but fine if there aren’t and i can understand it’s hard to give advice without seeing it
On a separate note I did speak to a friends tiler who is very good and hence booked out for 6 months which is why I couldn’t use him - he has done a lot of UFH and he said the hollow sounds are normal as the XPs foam type board is very thin and almost hollow- he said this will resolve once the tiles are fitted
Thanks again
Steve, forget all the he said she said nonsense. Whatever they have done, movement and the board bouncing is only going to end one way. Wish we had photos of some of this progress.
The other Tiler suggesting it sounding hollow is fine is right but the board isn’t just hollow sounding, it’s also moving = not fine.
Yes correct over 35sqm I have found approx 8 patches of about 15 cm square each where there is a slight movement due to air in there
I will just ask whoever tiles it to cut these sections out without damaging mat before tiling
The rest of the floor is sound and no point taking the whole lot out
Sorry one final question - assume that I should insist the tiler applies primer on SLC before tiling
I know that’s what was advised above but just want to be 100% sure as there seem to be different views on this
You can not say you followed Harry's advice you left out levelling before boarding .
Good luck cutting out 150 mm squares with approx 50 mm wire spacings
Yes as I said I followed the Tiler’s advice who said SLC wasn’t needed - cowboy tiler !
As for cutting if my new tiler is confident they can cut around the wire safely to remove dead spots then great if not will go ahead with tiling as it’s such a small area anyway
Is there any way to drill a small hole and inject some adhesive in the gaps that would be the most sensible answer ? Not sure if anyone has any experience of this ?
Steve01,
Bond,
Steve01,
Bond,
