Tiling concrete floor and UF heating
Ive fixed those un-coated boards a few times and never primed either side of em yet..just stick them with a wetter mix of adhesive making sure not to trap any air pockets under them. The problems here have come from trying to stick them to a floor that wasn't leveled over in the first place..
hi Andy
not looking for argument on the subject and maybe getting of topic as harry said, but why prime top and not bottom? Both are stuck with adhesive
hi Andy
I wouldn't use them again but priming the top would help the ufh adhere properly and prevent any curling and also aid flow of levelling compound
I haven't found a background yet that priming is detrimental . No need to prime and do not under any circumstances prime are two different things. But i havent used those cheap uncoated boards
looks like I'm out number but will still prime both sides as I believe it should be, have seen how bad a S1 adhesive sticks to an unprimed surface and sadly not found another product I'm happy using for wet heat. As for electric I'd use a covered backer board.
looking forward to reading other posts and giving input if I think it will be of assistance, please be gentle with the newbe
Depends on the adhesive being used.
Some state do NOT prime cement boards or light weight backer boards...
I've had that before . One which springs to mind was bal saying that about ply ( not that I was tiling to ply ) but it was in a similar conversation to this . So rang them up and challenged them over it ( I particularly like challenging bal self proclaimed messiah's of tiling ) and their response was you can prime it if you want to without affecting performance .
This is taken from there pdf, the adhesive is bal single part fast flex, an adhesive I use all the time on wooden substrates with cement boards...
Right if you look at next paragraph down that is what I challenged them on. Saying do not prime surfaces to be tiled on . I challenged them and they ok not a problem . So I wouldn't rely on that . I've not finished bal tech will get a call from Mr pain in the arse from salisbury
Steve01,
Bond,
Steve01,
Bond,
