Discuss Which mosaic trowel? in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
I have one of these......
Rubi Stainless Steel - 3 mm x 3 mm
Rustproof stainless steel blade
Comfortable and durable rubber grip
3 mm square notch, ideal for mosaics
Rubi's top of the range trowel
Dave has a very good selection of trowels.... TradeTiler.Ltd Trowels
Thats the very chap that I have in my toolbox dave.
sWe
3mm square-notch for mosaics thicker than 4mm, and v-notch for those thinner than 4mm, but not always. More on that soon.
Those thinner than 4mm tend to be no bigger than 20mm, and if the substrate is flat enough, the 3mm v-notch will probably work better than square notched, ie minimizing addy pusing into joints, while still achieving good coverage. This is especially relevant when the mosaics have paper or plastic facing (as opposed to net backing), because you REALLY want to minimize the risk of addy pushing into the joints when working on mosaics, as cleaning out excess addy is a real time sink if you get sloppy.
If the mosaics have net backing, it tends to minimize axcess addy in the joints, as it helps containing the addy, but not so with paper or plastic faced mosaics. Make REALLY damn sure the substrate is flat when working those kinds of mosaic, as you could end up spending hours raking out excess addy otherwise, since you can't remove it straight away without removing the facing, which will take the tiles with it...
Rob Z
Speaking of mosaics and dealing with setting material oozing into the joints....do any of you have access to a product such as Laticrete 4237 admix?
Lat 4237 is a latex additive that has all the goodies in it so that when mixed with sand and cement it will make a thinset mortar. The neat-o trick with this stuff is that it can be mixed with sanded grout to make a color-matched setting material.
Set the tiles as you usually would, and allow the ooze to come up into the joints and strike it off with a grout float and a sponge, and then grout the next day with the same grout that was used with the 4237. The color match is perfect and there is no time spent raking out grout joints.
Even if Laticrete isn't available in the UK, hopefully there is a company there that sells a similar product for you to try.
sWe
That's kind of clever actually. Laticrete is availible in Sweden, but their products are hard to come by, as they don't seem to have any retailers, which means you have to buy directly from Laticrete. Next time I re-do my own bathroom though, I'm going to order some Spectralock Pro grout with glow-in-the-dark dazzle :santa_cheesy:
Reply to Which mosaic trowel? in the British & UK Tiling Forum area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
    • Informative
We used 12x12 mosaic sheets of calacatta marble tile on our shower floor. During installation...
We had a wet room fitted by a large company. We have issues with a few large steps where the...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
