rj1884
Schluter recommend sticking Ditra to wood using ardex af200. It's basically like a glue in a tub
Thanks all so far.
Well, further unscientific testing with BAL SPF mixed slightly looser than usual but still holding a notch didn't work either. Ditra pulled straight off this morning. Not a trace of adhesive on the underside of the mat. Doesn't seem to penetrate the fleece to form a bond. Will try some Ardex next. At least the Mapei had 100% covergae of both the ply and the fleece. It just didn't set.
Stef, thanks for your advice dwangs n all! I may install the way you suggest. Would be slightly cheaper I think. Also, I want to be confident that when the floor is down it's staying down!
