Which Sigma?
AMtek
This might be a stupid question but i am well and truely confused by all the different handle configurations on the sigmas. What i want is a 700mm with a mormal push to score and push down to break handle so which one do i need??
Go for 3dm its great on porcelain.
Thanks for that but its a bit big, none of the tile shops round here even stock anything bigger than 600mm! stuck in a bit of a time warp. I'm sure i might see some 1200 thin porcelain but probably in about 2-3 years. i kid you not!
Best getting the 700 as the 600 machine will be no use when you're doing 600 on the diagonal. If you remove the rule you can squeeze an extra few cm out of it so in reality it'll cut closer to 800.
Yep exactly why i'm after a 700, nothing worse than trying to squeeze tiles in that are at the limit of what the cutter can cope with.
Thanks Dave, what is their price? about the cheapest i have seen is 300
Rubi TX700N :thumbsup:
Sigma 3BM you can get online. The best cutter i have ever bought and I have had a few. It has though taken me long enough to work out how to attach the measuring arm when transporting around. Now the cutter is even better. Okay should have read the instructions but in honesty how many of us do???
Paid for my 3dm 320 pound delivered of ebay.De 93cm bed cuts 60cm tile diagonal thats for exta 20F
Sigma... made in Italy..
Rubi ... Used to be made in Spain... now...
If your going for a sigma then I'd be getting the pull handle tbh
Not sure i could get away with a pull handle, always used push cutters and if it ain't broke don't fix it, or in this case if you can't break it buy a new cutter!
You know what .. i used to think that way, now i love the pull handle.. i truly do ..
This isn't what i need to hear! haha. spent the best part of a year swaying between tx, sigma and montolit now i have made a firm decision i want a sigma and now i have to decide which handle i want.
Problem is there are a few rubi stockists near me but i haven't even seen another tiler with a sigma round here so i can't test one
But is the push best then or is there something I'm missing, I did have the art 75 sold it when things slowed down I'm using a friends art 75 pull was looking at the tecnica 2B3 it's half the weight or the new max which is twice the weight but also has a wider bed any of you's try them thanks
I have a 3CM max , the thing is an animal, I used to have a tx700 but sold it to buy a sigma, I have never looked back, it's much more sturdy,lighter, more breaking power and the machine is just totally without fault. To me the hand/ wrist action of the original pull to score sigma design feels cackhanded and I often can't generate the force to score the tile properly using that method. That being said, pull to score is much faster when you get the hang of it and you have the advantage of resting the tile against the bar when scoring because you are going towards the bar not pushing away from it. You can use the max handle as a pull too but I don't think it is as good at doing this as the original sigma handles if I'm honest.
For an ex Rubi user like myself the push to score mechanism of the max series is going to be easier for you to get to grips with so for that reason the 3CM /3C2M/ 3C3M would be my recommendation the latter 2 machines are newer and have the facility to easily change handles and the handles themselves can be purchased from tradetiler at a reasonable price and will allow experimentation with different scoring techniques without the need to buy a new machine. Hope this helps.
Which Sigma?
AMtek,
DP Tiling,
AMtek,
DP Tiling,
