Discuss Which Silicon ? in the Australia Tiling Forum area at TilersForums.com.
White Room
Whitebeam Do you mean the remover, I think it was called sil out , used to cut main body out with a blade then apply thin layer to remove residue , worked in small sections as could be a bit messy but seam to work well. Can you suggest a good one for me as asked to recommend quite often
It was something like the Everbuild Silicon eater I used...
F
Fliselege
I use P.C.I 99% of the time as that's what my main tile shop stocks, grout too. Sometimes a customer will insist on what they saw on display in other shops, so every now and again use Shönöx or Mapei if that's what they want, all the same to me, does the job. Hate mapei products, addy ok, grout crap, Silicon stinks of vinegar.
White Room
Tried the PCI grout once and what a gem to use...
F
Fliselege
I believe that PCI pulled out from UK market....
might be wrong tho..
I've seen that said on here before, shame for you lot, great brand. Would be interested to know if it's just been re branded as B.A.S.F. Will have to do some internet research. Right after Top Gear. Unless Chatty Man is on too. BBC entertainment more entertaining than tiling on a Sunday night. Sometime later. ;-)
Reply to Which Silicon ? in the Australia Tiling Forum area at TilersForums.com
Derbyshire
Website
http://Www.andrewhindesinteriors.co.uk
Which Silicon ?
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
