Discuss Which trowel and grout line size for my tiles please? in the British & UK Tiling Forum area at TilersForums.com.
E
essexsi
Hi all,
Thanks for the great help I have recieved in other questions.
Hopefully a couple of quick and easy answers for you pro's!!!
The following is in a walk in shower and the area will be tanked appropriately. I think I am right to be using a flexi adhesive on both with a long bucket life as this is first proper DIY tiling job, Ardex 7+G I believe is well thought of.
Wall
Plaster on block
Ceramic Tile size 300x600mm
Was thinking of using a 10mm trowel and using a 2mm grout line. Am I close?
Floor
Concrete screed
Ceramic tile size 300x300mm
Was thinking the same 10mm trowel as wall but maybe a 3mm grout line for the floor.
Any input appreciated.
Cheers Si
Time's Ran Out
Si - Agreed with others - however I'd tend to keep the joint size the same and therefore you should be able to follow the wall and floor joints (1 wall tile to 2 floor tiles).
I said should because the extra joint in the floor tiles may push the line out. Check the tiles prior to setting out the room as some matching tiles for wall/floor tend to manufactured with a joint allowance.:thumbsup:
John.
DHTiling
As john mentions though..check the tolerance of the wall tiles against the floor tiles..Some manufactures make the floor tiles slightly smaller to allow for the extra in the joint....
And yes i have used 10mm both walls and floor....say you used an 8 mm and the coverage isn't sufficent then step up a trowel size..
Daz
Lol John,
Sorry I obviously didn't read it carefully.
Nah my bathboard is still lovely and clean. I thought I might wrap it in clingfilm to make cleaning easy.
Do you remember covering your school books with wallpaper to protect them? I might do my bathboard in some dodgy old stuff that I have lying around :lol::lol:.
DHTiling
Lol John,
was poor...woodchip..:lol:
Reply to Which trowel and grout line size for my tiles please? in the British & UK Tiling Forum area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
