Discuss which trowel size in the British & UK Tiling Forum area at TilersForums.com.
charlie-d
I have tackled ceramic tiling in a bathroom before around bath and sink, I used a 6mm square notched trowel. I am now going to tackle my old shower which I have ripped out I have re studded the wall and sheeted it with green board Gyproc and tanked it. I have 300x300mm ceramic tiles. I intend to use bagged Bal flex adhesive for these tiles within the shower area. I have read several posts relating to trowel size and I am a bit confused. The walls are flat and plumb.
Do I need a thin bed solid bed trowel, if so which size, v - shaped, square notch or U- shaped, 5mm, 6mm, 8mm, 10mm etc.
Any help would be appreciated
Diamond Pool Finishers
6mm for me
doug boardley
Thank you both for the fast replies. I found a trowel on the internet
it states its a thin bed solid bed trowel its a v-notch 9mm x 5mm I assume the 5mm is the depth. would this be to shallow which type/make would suggest.
Thanx
the 5mm might be the distance or gape between the points and 9mm the actual depth:thumbsup:
Reply to which trowel size in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
which trowel size
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
