Mike Mike
My transit is rubbish! New diesel pump ...900 quid, new flywheel 800 quid, all comon faults apparently! Only done 70k, oh and the rust! In the last year...Gearbox selector siezed, power steering pulley siezed, slave cylinder leak. I will never ever buy a transit again! Suppose its just your luck but I have lost all faith in Ford! Think my next van will be a berlingo, had one for 2 year and nothing ever went wrong with it and it was not a new one at the time.
Come on now, be reasonable. It's not Ford's fault, its the Germans.
Ford Transit 2000 - 2001 2.0 2.4 DiProblem: Engine running problems, lack of power and / or failure to start.
Solution: The Transit with the 2.0 and 2.4 DuroTorq Di diesel engines suffer from a failing Bosch injection pump. The cam plate fails in the Bosch VP30 fuel injection pump. The solution is to fit a revised and modified injection pump. The fuel system should be thoroughly cleaned and checked for any metal particles in the fuel system. The revised injection pump has been installed since 12/2001.
Flywheel is their fault, but hey, no one's perfect, :lol:
Ford Transit (rear-wheel drive) 2.4 Di up to 2002
Problem: Repeated premature clutch failure and possible damaged dual mass flywheel.
Solution: A revised final drive ratio (5.13) rear axle should be fitted. This will reduce the top speed of the vehicle, but will aid in situations such as a steep hill with full load, preventing repeat clutch failure.
