jaykay01
Hi all,
My first post on the forum, however i have used it from time to time to gain valuable knowledge and hints/tips.
I have done various tiling jobs in kitchens and bathrooms as a skilled "DIY'er" for want of a much better term :lol: and have started to find that i am getting more and more work doing it. Anyway my lastest job that i am going to take on is a bit of shambles. The task is to tile a bathroom floor using cermic tiles 150x400mm. It has been stripped out and started by the owner and his plumber.
The scenario...
Bath and shower tray are already fitted in place on to the floor boards. Customer doesnt want to remove the bath and shower tray and allow me to strip floor boards up and put down 25mm ply.... BUT... wants the finished level of the bathroom to remain as low as possible to avoid a large step up from the hall!
The customer has loose wire type (not mat) UFH which he wants me to put down.
What is my best option? Fix the floorboards down as securely as possible, they are mostly free from deflection at the momennt anyway. Adhesive and screw 6mm hardie backer. Fix UFH down to backer board. SLC. Tile. In this order?
I have never used Ditra matting but understand this MIGHT be an option from what i have searched on here. the floor boards are fairly flat and free from gaps? If I used Ditra mat what order would i lay down the UFH and SLC?
Any help would be greatly appreciated. Being from an engineering background i cannot stand to cut corners and want it to be right (well as right as the customer will let me do it).
Thanks in advance.
Jez
The scenario...
Thanks in advance.
Jez
