Which wet cutter?
I have a rubi Diamante D200 table saw. 1.2hp motor and cuts anything...expensive machine at around £580 but will last years and years....i have the rubi dw250n rail saw as well again a good cutter but well heavy...i too have been looking at the dewalt 24000..
Larryplum - The Norton TT200B is the wet cutter I first mentioned and it has an enclosed water tank which apparently you can carry around. It is only around the £230 mark so should be within your budget.:thumbsup:
I looked at the Norton rail type cutter however it doesn't cut 600mm and the rails restrict the cutting line view.:thumbsdown:
I doubt if you can get the Rubi D200 for £350 and if you dont do enough to warrant getting the Dewalt 24000 the the Clipper is next IMO.
Question - Larry do you have any relations associated with Cluedo!:thumbsup:
John.
if you can stretch the budget to around £700 go for the dewalt 24000 from tradetiler got one the other week and its the best wet cutter out there by far seen one second hand for £400 in my local tile shop so you can get them cheaper if you are willing to go secondhand!
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
