Unfortunately Mark, I did not produce the image. I just copied it straight in to the post.
Because you’re adding the weight of the ping pong ball and string.but why?!
Why . Is it because the tube protrudes lower into 4 . Because if so water finds its own level and will fill the receptacle and tube as well . 4 is also filled from a lower point than 5 .only 5 can be filled.
It’s 3 Jerry, enlarge the image and look closely at the pipes.Why . Is it because the tube protrudes lower into 4 . Because if so water finds its own level and will fill the receptacle and tube as well . 4 is also filled from a lower point than 5 .
