why is the fein multimaster so crap..
steve9999
used my brand new multimaster today to remove a screw that was sticking out from a wall and i was there a good ten minutes!!!!!!!!, looked at the brand new blade after and it was worn down quite a bit. ah well only £25 for a new blade that was used once. this has to be one of the most overpriced tools for performance(very underpowered). its a d.i.y tool and not for the trade. and i tried it on removing wall adhesive and it was not much better at that either. just takes off the top layer and leaves the rest. it is the newer version with the better motor and the blade i used(to remove the screw) was for metal and wood.
got to disagree with you steve m8.Did you use the correct cutting tool/AS FOR THE ADHESIVE ..WET IT FIRST THEN USE THE BLUNT TOOL BIT AND IT COMES OFF A DODDLE.Sorry to hear you didnt like it...Did you have it turned up full m8 ..black nob at side?I love mine and use it on most jobs.:thumbsup:
turned up full and blade was for metal/wood so unless it cant even cut a screw in half ......i will try wetting the adhesive next time for removal
Never had that problem, cuts screws , nails and anything else i throw at it within seconds. I agree about cost of blades though.
Only have to touch a screw with a Fein and it cuts off! Really cannot be using it right (no offense) As for it being a "DIY tool" couldnt be further from the truth, class tool. Fein is a very very good quality maker of tools. P.S. what blade was you using to remove the screw?
these are a absolute giveaway, ive had one for 3 years and its still going strong.
Lidl Online
these are great as well.
Lidl Online
they only do these once a year so grab em quick,if they aint already gone.
Those cycling Briefs caught my eye. I hear Wivers likes that kind of outfit
With antibacterial Coolmax® padded seat area
Sizes: S - XXL
only £2.99
Lidl Online
Sorry to hear you arent happy with your fein mate gotta say i think mine is great very handy love it for cutting under doorlinings and architraves. sure yours aint playing up mate? Agree with you on the blades though overpriced mate.:thumbsup:
ted
Steve..............did you plug it in :grin:
Used mine today as well..............removing addy from wall........and from back of slate :thumbsup:
i think he has got a point about the blades i find that they dont last long at all and are very expensive i do think that the multimaster is a really useful tool i have been buying the bosch blades and altering the to fit my fein tool they last longer than the fein replacement blades imo
I love the Fein but I too have had some blades that just blunt straight away when I try to cut screws,they shouldn't do that for that price.
Used mine today for re-grout and np's apart from the blades dying. Had good use outta them though,but still to dear.
Never had a problem with my multimaster - does exactly what I want every time. I do agree that the replacement blades and attachments are very expensive though.
The fein is very good but the blades that come with it are crap...to give you an idea i'm working on a regrouting job at moment used the carbide blade that comes with the tilers kit got through 2m2 of grout and it was a gonna.
Had to order a diamond blade special delivery to get job finished tmw. Now if that one doesn't last i won't be happy can't see the customer paying more than 60 a pop for blades, might end up being cheaper to retile!
u should have got much more than that Freed. Were u forcing it to blunt it. I just let the fein work with just a little pressure and it will last a lot longer.
Maybe i was pushing a little to hard....but i'm sure those carbide blades are short life i recommend any1 whos got a large job to take along a few of them or buy a diamond one otherwise ure going to be waiting 10 minites per 5cm of grout line for blade to eat the grout!
Just got my Fein today. £152.50 brand new inc. postage from ebay shop. Good price. So far, very impressed. I'd never heard of it, until I joined this forum. Wish I'd had one years ago, it does a lot of awkward things, that doing any other way is a pain.
So far, its a success. However, I must say the manual is really poor. There is no real description about which tool to use for which job. I find that a great shame. It means I have to trial and error each blade. And already I have worn the adhesive removing blade, by trying it on some hard grout. Sure - shouldn't have used it for that - but nothing in the manual says I shouldn't. I just wanted to clean the end of a tile run on the floor, because they are having carpet laid upto the join. It was doing the job fine, but was worn on one side. Tried the carbide blade next the circular one. That seemed to cut - but slowly. Did the job, but not that speedily. Perhaps again, that's not the right attachment for that task. But removing the grout by using a hammer and bolster was damn hard work and risked chipping the tile edge - so it is still an improvement.
Used the blade to cut some old coving, I was installing some new stuff joining the old, in my own house. Difficult to cut into the existing using any kind of saw. However the Fein did a superb job. Also tried the scraper over some wood filler, took the top of it off beautifully.
So far - impressed. I think I just need to learn more about which blade does what.
Which is the HSS blade? Should that be in my TOP kit? I think its the wood/metal blade that is in there. Do I need to buy an HSS blade as an extra? And which blade is the grout removal blade? The carbide one - or is it the other funny circular one?
Paul
the circular saw blade i felt was pretty brittle ,either that or it wasnt in the slots properly ,so make sure you get the blade in the slots guys.:thumbsup:I agree with you all the blades are expensive but back to the original quote...its not crap is it!:thumbsup:
seen that bosch and works have something similar out anyone used them? £70 seems ok price similar idear
I think my fein is great too lads,
blades are too expensive but so are a lot of tools lately,
mine gets lots of use mostly cutting the bottoms off architrives,
the only prob with this is hitting the wall and blunting the blade etc so i bought the solution !!!!!!!!!!!!! yes.
I bought a fein depth stop from TT and works a bloody treat,
i have it screwed tight to my fein and is doing a great job protecting my new blades from TT too,(expensive though,lol).
Check them out lads on Davids website.
I use my fein everyday and it is really good, i use it to cut the bread for my sandwiches, spread the butter, cut the cheese then i put it back in its box, never worn a blade out yet...well im only cutting cheddar havent used it on whole meal bread as im worried it will wear the blades out to quick...:lol:
Nice piece of Kit! Greatm for stone edges and edge polishing in situ. Also brilliant for cleaning the area when you have to remove single tiles:thumbsup:
Kev
i have to say that its more the blades that are crap. the multimaster is a very good tool but a bit under powered.
Tags Tags
fein usa
UK Tiling Forum; UK
steve9999,
poynton phil,
steve9999,
poynton phil,
