Stefan
I need to raise my shower tray (800mm quad) by ~160mm. The tray instructions recommend either building a riser from 2x4 and bedding in cement on marine ply, or using an easy-plumb riser kit.
The riser kit is about £50. It's only 100mm high, so I'd need to add some height with 2x4, but that's simple. I'd then need to replace the PVC sides with some standard sofit.
Building a platform from 2x4 (1 on edge, 1 on side to give 150mm) and marine ply seems straightforward, but the cost of the marine ply is prohibitive - £78 (non-trade) for a sheet of ply.
So it seems to be a simple choice - the riser kit is cheaper and less effort. But lots of people recommend building your own...it seems so obvious that I'm worried I must have missed something!?
What do the pros do?
Thanks!
Thanks!
