Discuss Will they stay stuck? in the Canada Tile Advice area at TilersForums.com.
davo66
Any opinions whether there appears to be enough adhesive behind my tiles to keep them stuck to the wall of my shower cubicle, and prevent water ingress behind the tiles?
As can be seen I’ve removed one of the offending tiles to show how the adhesive doesn’t go all the way to the tile edges, especially at the corners. My question is whether the rest of the offending tiles need to be removed and replaced, before grouting?
This is sent as a follow up to a previous post on this forum about whether this job was at risk of leaking:
"looks-like-could-leaky-one"
cheers,
Davo
davo66
take the tiles off if they have been dotted and dabbed or you will have trouble,that is not the right way to fix tiles
Would you say it looks like it's been dot and dabbed from the attached photo? - the tiles are green and the adhesive is the grey splodge, which kind of looks like a number 8 on its side. The slightly darker area of grey in the corners are free from adhesive
davo66
try this for on line resize try 350pixel setting - Resize Images online
i use this one installed on pc, just drag and drop photo, and will reduce automatically - Batch Picture Resize
Thanks Steve, I've managed to create a better photo (by cropping) but now I am unable to upload it as I only have 4.2kb left from the 9.8Kb allocation and there doesn't appear to be any way of removing the originally posted photo under the attachment management window.
Sorry to be a dimbo, but I don't suppose you know of any way to remove a picture from a post?
Reply to Will they stay stuck? in the Canada Tile Advice area at TilersForums.com
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
