Discuss Window Ledges in the UK Tiling Forum area at TilersForums.com.
DazJWood
All,
I am started tiling with my travertine tiles and am wondering which is the best way to approach the window ledges.
I have already decided that I will be using a butt joint for them and then chamferring the top edge off.
Should I be laying the "ledge" down first and then measuring and cutting the vertical tiles up the wall to the ledge after or should I cut and fix the tiles up the wall (to the top off the ledge) and then fix the ledge tiles after?
Or does it really not matter? I am just trying to avoid having any odd sized gaps between the ledge and top row of tiles. I guess if I measure right it shouldn't matter which way. Am I right or are there any tips or techniques anyone can give me to ensure an ideal fit? I have a few external corners that will probably benefit from any similar tips/techniques, if there are any.
Thanks in advance,
Daz
DazJWood
ah, after re-reading your post, it loos like you've called the head, the ledge:thumbsup:
No, my window has no "head" or top to it. It goes straight to the ceiling.
It was probably my explanation making it confusing. I wasn't actually asking about which order to do the sill, head and inside verticals. I was trying to understand how specifically to get the right levels and grout spacing between the sill and the wall meeting it (below the sill). It was probably my naff explanation :).
CCTiling has given me the answer.
Thanks,
Daz
Reply to Window Ledges in the UK Tiling Forum area at TilersForums.com
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Window Ledges
