Discuss Window recess in the British & UK Tiling Forum area at TilersForums.com.
aph257
What's the best way to keep the tiles fixed to the underside of the recess? I used lenghts of batton for each tile, but is there an easier way.
another related question:
Which is the correct way to put the trim on? i did it with the flat/flange side in the recess. i ask because i'm taking tiles off for another customer and the trim was around the outside of the recess!!
Gazzer
The best way is the way you feel comfortable with, Battens are ok, I use 2 woodworkers clamps that can "spread" as well as clamp
And the trim should fit inside the reveal.
doug boardley
do you mean on the window head inside the recess aph?
Scott
I use those too doug, full size ones propped off the floor. I use them on all headers as i had a tile fall off once and damage a vanity worktop.
Got them from Aldi of all places, i think they were about £6 each so ridiculously cheap.
(Work well for holding skirting boards on until the gripfil goes off too if you lay them across the floor)
DHTiling
I rarely use anything to hold them up other than the suction from the tile adhesive itself, and also fit the flat edge of the trim on the wall as oppose to the reveal. Each to their own method but bein doin it this way for years with success:thumbsup:
Same method here... i can hang a 12mm stone slab and it won't drop off...it's all in the suction as they say..
doug boardley
I got one from Aldi too Scottley, only when I put a bit too much tension on, it snapped the trigger:yikes:
The Legend; Phil Hobson RIP
As above I use suction for soffits. But on heavy porcelain over the window head I use the same as Doug. The 1st ones I bought were from B&Q £20 then I bought some more from Aldi the £6 ones all still going strong, I have six now. Handy when you are doing a bathroom with two windows and a door:thumbsup:
Reply to Window recess in the British & UK Tiling Forum area at TilersForums.com
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
I have a small kitchen with a floor area of 265cm x 140cm with the door recess adding another 20...
Hi everyone Looking soon at retiling a shower enclosure walls at a local leisure centre. Once...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Hi, 1st time tiling, decided our ensuite would benefit from being a wetroom. Quick question, any...
Window recess
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
