Discuss Would you prime this concrete floor? in the British & UK Tiling Forum area at TilersForums.com.
DJT75
Hi
Doing my first bit of floor tiling this weekend & I'm not sure If I need to prime it or not.
It's a 3 sq metre porch, currently has carpet & underlay on top of some crappy old very thin 'plastic looking' council flat tiles. The tiles are completely loose from the concrete below.
There doesn't appear to be any adhesive to pull up, it would simple be a bit of a scrape around & a good hoover to leave a decent concrete floor to tile on. But should I be priming it?
If so what products would you recommend & how long do I have to leave it before I can start tiling.
I'm laying 300mm-300mm ceramics using BAL rapid set adhesive & BAL wide joint grout. I assume 5mm grout lines are appropriate here?
thanks
Ajax123
1,213
Lincolnshire
Might be better to use SBR or Epoxy in this instance. Unless I am mistaken Bal APD is an acrylic. Old Council Vinyl Tiles used to be stuck down with styrene based glues (like Evostick) Styrene Butadiene dissolves acrylic so has the potential unless you know the floor is perfectly clean to give you some problems long term. Neither SBR nor Epoxy will be affected the same way.
DJT75
Sorry i wasnt having a go at you
just the question i think maybe the training schools need to look at some of the info and regular questions we get asked on here and maybe take our advice on
No worries.
The training does cover it - like you some of the trainers say if in doubt just prime it. But I was interested in the view of others equally as experienced & as you can see I've had a variety of answers, including a completely different angle from Ajax123.
However. this stuff has been down for donkeys years, it's a small porch & I've just shelled out for some APD on a job I'm not getting paid for (mother-in-law) so it's going down! :yikes:
H
heavytrevy
I always prime if im waterproofing over hardiplex /plaster/concrete.
If ur just sticking/tiling with thinset to a mortar screed / concrete slab u can get away with using a damp rag a couple squares ahead of where ur workin.
Also if ur tiling hard concrete anywhere from 35 mpa- 50 mpa i recommend
shot peening or and acid wash so ur thinset has something to grab to, although not needed if the slab has been broom finished /wood floated.
Hope this clears a few things up.
Regards
Trev
Reply to Would you prime this concrete floor? in the British & UK Tiling Forum area at TilersForums.com
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
