Discuss wrong size trim? in the British & UK Tiling Forum area at TilersForums.com.
silver
sorry guys if I gave the impression it was my job.....didnt realise my reply read like that...till I read it back. ! doh:mad2:
I wouldnt let that happen..!
...whoever has obviously used the wrong trim.....maybe only had one size in the van ? and wanted to get off the job ?
I was trying to say that sometimes I have found a bit of overhang from using bevelled tiles brick bond fixed.
Olz
I won a qoute yesterday based soley on the fact that the other tiler that had qouted had tried to convince the customer to only have upright trims on a half height splashback, with no trims on the tops of the tiles upto and into the window, the customer said that the tiler had said that a three way cut would look too cluttered, the customer immediatley thought that the tiler couldnt do the three way cut, despite the tiler trying to blag it. :lol:
The customer said my qoute was more expensive but he had no confidence in the other guy.
no sorry , tiles are finished flush with tile trims , no 1 mm overhang . sorry guys not good enough , or is it just me ?. always if in doubt go a litt le thicker with the trim and build out so that the tiles finished flush. nothing worse than tiles overhanging trim even if it is only a mm.
Olz
unless i've misread mate, the trim is overhanging the tiles, not the tiles overhanging the trim
grumpygrouter
there are a lot of these brick shape tiles that you simply cannot trim with out overhang,and yes it looks crap.
the only way to do them is MITRE,and charge plenty for it.
Yes you are right Oldgit. One way to reduce the problem if you know you have to trim is to set out so you end up with a 1/4 3/4 cut where the trim is going to be. Doesn't eliminate the problem but it reduces it greatly.
oldgit
so true the biggest mistake with these tiles is to start whole and half.
Reply to wrong size trim? in the British & UK Tiling Forum area at TilersForums.com
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
wrong size trim?
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
