Discuss Advice for 100m2 Home in the Tiling on Underfloor Heating area at TilersForums.com.
Sheldon Overs
All
I have a house which has block and beam with 2 depths of space to play with for Water UFH.
I have either a 55mm screed or a 85mm screed (house on 2 levels). I have dug holes so I can see what I have but not dug up all the screed yet. I also have timber suspended too but this I guess is far simpler to decide what to do.
So I have concrete block and beam with 55mm depth to play with what system would you do? 10mm insulation and self leveling screed?
85mm? 30mm insulation and self leveling screed?
Or should I really be going for these thin overlay systems? If so which one and what build up? On a positive note the Mrs is happy with tiles everywhere bar the living room which is perfect for UFH.
I hear so much conflicting advice with regard to insulation, but I REALLY want UFH, we are fully refurbishing house (Elec,Water,Decoration)
Thanks All for this
Sheldon
Sheldon Overs
Thanks for the reply.
I have block and beam with screed ontop, no insulation above (unsure about below but I doubt it). I will dig u the screed to give the above depths before I hit the concrete (I only have 30-50mm screed)
I know half people say mad not to have any insulation and others say fine. But I can get 20mm insulation in with bekotec-therm (40mm)in some rooms, and then 50mm insulation with bekotec-therm (40m) in others.
Reply to Advice for 100m2 Home in the Tiling on Underfloor Heating area at TilersForums.com
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Sticky
  • Question
