Discuss Advice on moisture resistant plasterboard in the Tanking and Wetrooms area at TilersForums.com.
Dan17h
Hi guys,
I'm in the process of redoing the bathroom. I've removed everything including tiles and found that the plaster is hollow and loose to the brick on 2 walls. So I'm gonna remove back to bare brick on these 2 walls, tank the plasterboard and attach to the walls.
I just wanted some advice on a few things I'm unsure about to avoid any future issues.
What length and type of screws would you recommend for attaching 25mm timber studs to the walls?
Does moisture resistant plasterboard only hold a certain weight of tile?
Any other usefull advice you guys could add would be much appreciated.
Dan17h
I thought it would be better for the tiles to be attached to a battened wall, from what I read it's more secure but I could he wrong.
I was planning to use pinkgrip dry fix foam on 1 of the boarded walls as this won't be tiled.
Even with the dot and dab method, dont they still need to be screwed threw the dabs with wedi washers?
I just can't find any info on what type and length of screw to use and also if any plugs are required for the screws.
Dan17h
Didn't know mechanical fixings were only needed when boarding on old plaster.
What I'll do then is check the walls are fairly level. If not I'll do dot and dab as it will be easier to get straight and level.
Any of you guys had any experience with Everbuild pinkgrip dry fix? And if it's ok to use as dot and dab for bathroom walls?
Also I read somewhere that dot and dab isn't recommended on external walls as they are prone to damp or condensation. Any truth to this?
Cranbrook
No truth to that mate, condensation is the majority of the time due to a lack of air circulation, and damp will come through whether you you use plasterboard or anything else, if there is a dampm problem to begin with
Spare Tool
The only time you need mechanical fixings on plasterboard is if it’s PIR thermal board. Each board requires two fixings only. This is to meet the fire regs.
Yes, condensation is usually formed in houses with solid wall construction (no cavity) due to the humid air inside touching the cold walls.
Plasterboard on external walls actually stops this but you do need a vapour barrier.
So no fixings when dot and dabbing over plaster skim or scratchcoat then ? :|
Waluigi
I’m not entirely sure. I tend to knock back to block/brick.
I suppose the PIR board is pretty heavy and perhaps the foam is flammable so the board doesn’t want to fall off the wall in the event of a fire.
I was told it was to stop fire spreading too so the mechanical fixing might not be a bad idea against skim/scratch. The bond against a block wall is pretty much guaranteed so no mechanical fixing required.
Reply to Advice on moisture resistant plasterboard in the Tanking and Wetrooms area at TilersForums.com
