Discuss Bathroom tiling adhesive and clips advice. advice and in the Tile Adhesive / Grout Advice area at TilersForums.com.
M83T
183
Devon
I have been asked to tile my cousins bathroom and it will be my first time using 300x 600 ceramic for the wall. The tiles are going on a skimmed wall which is in good nick, can anybody reccomend a decent slow setting adhesive to use for this please. And also is it worth using clips to get them good, it's not a huge area but I do struggle with lippage because I'm still very much a learner. I haven't said yes to doing it yet but I am keen to try it for some experience, any advice on the above or anything else I should consider? Thanks
M83T
183
Devon
Tilemaster setaflex standard set is a good adhesive to use.
In regards to clips each member has there own preference mine personally is perfect level master.
Thanks! Does the setaflex have a decent working time, I've just done some travetine for someone and the adhesive they supplied went off so quickly it really caused me some headaches!!! I was vying toward perfect level master.
M83T
183
Devon
Skimmed walls generally appear good till you get a straight edge on them, especially around the windows, spend some time doing this and after priming skimming out any dips with adhesive..it'll save you a lot of headaches later on
:thumbsup:
Agreed I will have a good check, they are ready to move in and unfortunately have left the bathroom until last so they are in a rush to get it done I'm going to tile their kitchen but I'm unsure about the bathroom walls above the bath, I was going to SBR the walls then tile but should I waterproof the walls for the over bath shower??
Reply to Bathroom tiling adhesive and clips advice. advice and in the Tile Adhesive / Grout Advice area at TilersForums.com
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
  • Question
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
