Discuss Deflection issue with No More Ply down in the DIY Tiling Forum area at TilersForums.com.
K
Kevbos
Or strengthen the floor before you start to tile .like you should do over any floorboards .6mm ply is not sturdy enough .at least 12mm 18mm preferably should be used .and ditra was made for a reason
Stef
Ditra wasn't made to take deflection!!
Deleted member 46792
I lived in Sweden too. They do a lot differently!
Ive been in again and looked at the bounce. You can definitely see the floor move but its mm rather than a cm. And im pretty big. And its in two small areas not all over.
Im going to try with the elastomeric adhesive. Thanks very much for all the help.
K
Kevbos
No but was made to help eradicate movement after preparing a floor properly
Good luck with the bal .just look up tiling overy floorboards .that 2mm will transfer into cracks
It will cost 100 pounds to strengthen floor why not just do that
aaargh...the 6mm NMP was supposed to do the job..as far as i understood 6mm NMP was supposed to do the job of 18mm ply...
You're probably right, ill sleep on it. I suppose the other concern is then the height increase between floor and hall...but that should be fixable with a decent threshold...
K
Kevbos
Yes as I said it's made to go over timber floors prepared properly .as timber contracts and expands .it helps the flexibility
Edp go buy a nice bit of oak same width as door liner use that to take out height difference
Stef
It's made to go over any substrate that is going to have any lateral movement in it.
I've heard too many people say that Ditra is a saviour to all problems, too many people think it's for bounce in a floor & if people see it being written like this then they will assume it is.
Reply to Deflection issue with No More Ply down in the DIY Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
