Discuss Exterior tiling on uneven existing concrete in the UK Tiling Forum area at TilersForums.com.
DHTiling
Hello Roy and welcome...
Not all levellers are suitable for external use...
These are a few options that are available use...
Fast-setting cement based levelling compound for internal and external use from 3 to 20 mm thick.
Applications:
Internal and external levelling compound for all normal supports used in building provided they are clean, such as concrete slabs, cement screeds, old ceramic flooring, terrazzo tile, natural stone.
Apply 3 to 10 mm thick per coat.Coverage
1,5 kg/m2 per mm of thickness.Packaging
25 kg bags.
ARDEX K 301 - Fast Setting Exterior Self-Smoothing Levelling and Resurfacing Compound
Size (pack): 25kg
Coverage: Approximately 1.6kg ARDEX K 301 powder/m²/ mm, i.e. approximately 7.8m² at 2mm thickness per 25kg bag.
ARDEX K 301 Exterior Self-Smoothing Levelling and Resurfacing Compound is a special fast setting cement-based product designed to smooth and level rough and damaged concrete surfaces in external and internal situations. ARDEX K 301 is a grey powder consisting of special cements, graded aggregates and high quality synthetic resins. When mixed with water, a fluid mortar is produced which sets within 2 hours and can normally be walked on after approximately 2-3 hours at 20°C. ARDEX K 301 can be applied from 2mm to 20mm in thickness. The set and hardened ARDEX K 301 is usually ready to receive light wheeled traffic after 48 hours at 20°C.
What tile do you intend to use..?
DHTiling
Dave,
How do you use those SLC's so that the pour ends up with a sloped surface (for drainage)?
Roy, I'd rather do a mud bed so that the money goes into the tile setter's pocket rather than pay for a lot of SLC. :thumbsup:
They are smoothing compounds Rob and can be treated like screeding , where as you form the falls and it goes from thick to thin , which you can't do with screed/mud jobs, like from 1 inch to 1/16th or summit.
Reply to Exterior tiling on uneven existing concrete in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
  • Question
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Sticky
  • Question
