Discuss Grey grout, matt white subway tiles...Staining? in the Tile Adhesive / Grout Advice area at TilersForums.com.
I've completed some matt white subway tiling in my bathroom and have started to do some of the grouting.
I've done one area of about 1sqm using Ardex FS grout in Ocean Grey colour. I'm unsure as to whether I should have sealed the matt subway tiles prior to using this grout.
The grouting doesn't appear to have caused any staining apart from small areas on a couple of tiles where there is some very faint grey stain. I don't know why it has only occurred in these couple of places as I grouted and cleaned the whole area in the same fashion.
I don't want to carry on unless I can prevent this happening worse in other areas.
Should I use some sort of sealer on the tiles before grouting any further?
Does the sealer affect the final sheen of matt white subway tiles?
Can I remove the small area of mild staining as I'm a bit of a perfectionist? I have some HG Limex somewhere if that's of any use.
Thanks for any help
F
Flintstone
:D
Reply to Grey grout, matt white subway tiles...Staining? in the Tile Adhesive / Grout Advice area at TilersForums.com
