Discuss Hello to you experts out there on Victorian Tile restoration in the UK Tiling Forum area at TilersForums.com.
Phil Robinson
Hey guys, Just joined the forum today and looking for some advice please. I am an avid DIY'er but have moved into an old 1905 house that has some geometric white and black tiles in the outside porch and the internal porch.
I have tried cleaning them with Lithofin tile Restorer, the area to be treated is only small 2m[SUP]2[/SUP] so thought I would do it myself. The lithofin has got a lot of the dirt off but the white tiles are still discoloured with dirt and slight pocketing.
I followed the instructions of putting the lithofin on agitated with a nail brush and left it for 15-20 mins and did not let it dry. But really keen to get the rest of this dirt out if I can.
Just wondering if there are any other products that I can use and also once they are cleaned what is best product then to seal and polish them with to get a nice luster/shine back on them. IMG_0705.jpg IMG_0706.jpg
Thanks for your help guys.
Regards
Phil
Time's Ran Out
:welcome: Phil - the tiles you asked about in your 2nd post are Encaustic - a mix of coloured cement poured into moulds. Extreme care should be taken using the following products anywhere near the darker colours of this material.
The porch tiles MAY come up better if you use a 15 per cent acid cleaner (patio/brick cleaner) washing with clean water. Or you could try Nitromorse (water soluble). With both these suggestions please test a discreet tile first and wear gloves and goggles.
Note : this advice is given in good faith and no responsibility for damage will be accepted.
Time's Ran Out
Also you say take care near the darker colours so the tiles are only black and white so I should keep the acid completely away from these tiles is that correct. Thanks Phil
The porosity of these tiles is such that too much cleaning (acid) will bleach the colour. You must test an area first and be ready to wash off immediately, for the area you have you could do a test area with a modelling paintbrush. You are looking for a lint type cloth to soak up the dirt from the pores of the tile.
When clean to your approval, the tiles must be bone dry before any seal is applied, 2/3 days without damp conditions, and Lithofin Stain Stop or impregnater will be ok. But make sure any excess is buffed off after 10/15minutes if lying on the surface.
Phil Robinson
will do guys and thanks for the advice I will take some before and after shots and lets hope its good. Some of the grout or cement between the tiles is really bad and I was reading that I should use a fine cement based grout is that correct and a couple need some adhesive again should i use a fine sand and cement mix for that to please.
I was thinking that once they are clean i should seal them before grouting what do you think? was thinking of using Bal fine cement grout?
tommyzooom
1,083
Ireland
Hi Phil,
Definately grey grout, and I would seal before grouting, you will find the grout is easier to clean off. It will need a couple of coats after the grout is dry too.
For cleaning, I cant add much more to what has been said, but you could try a steam cleaner, one of my clients swears by it for keeping beige floor grout clean
H
hutchinsons
hi there
thought i would give you my input too lol.
you normally find the white tiles are more stubborn to restore.
i think the main reason is perhaps they have been fired at a higher temperature making them less porous.
you can see this after you have stripped and cleaned your floor the other colours tend to dry out while the white ones stay wet for longer.
its just a case of persistence really. i like to us the HG products on the market and have had no trouble at all with the stripping and the sealing and polishing.
hope this helps.
Reply to Hello to you experts out there on Victorian Tile restoration in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
