Discuss Help with bad tile job and grout in the America Tile Forum area at TilersForums.com.
I was hoping for some advice.
I have large white tiles in my kitchen who a friend laid. I was away at the time he laid them so was unable to give him feel back and ask for them to be altered at the time. I absolutely hate the way they have been laid, the joints do not line up and he didn't use the same size spacers. I was hoping I would forget about it but it pains me every time I walk into the kitchen. The worst parts are covered by my island but ots still visible. Is there anything I can do without ripping them out and completely starting again?
Also in another section in my house I did not clean the black grout fast enough so it has set. No matter what I use or do I cannot get it off. O have used white vinegar, grout cleaner, a steamer and good old elbow grease. Any suggestions?
Thank you!
Reply to Help with bad tile job and grout in the America Tile Forum area at TilersForums.com
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
  • Question
