Discuss How to set out for an off centre window using bevelled metro tiles in the America Tile Forum area at TilersForums.com.
Nixxxy
Uk
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but looking for second opinions/better solutions.
I have a window off centre in my bathroom which I am wall tiling with bevelled metro tiles. If I centre from the window I get uneven cuts at each end and small. If I centre from the wall the cuts will look odd at the window corners.
I have fixed this (I think) with centre from the window and cutting part of the tile back 1 in from each side. Cut slightly more back on the RHS to create equal end pieces. Is this correct?
Photo 1 - centre from wall
Photo 2 - centre from window
Photo 3 - cuts to each 1 in from sides
46
478
Dorset
Don’t cut the tiles one in from end , especially bevelled metros!, it will look rubbish - honestly it’ll stick out like a sore thumb!
Looks like you have a 1700 bath, so about 8 1/2 metros across.
I’d start whole tile (or fraction less, depending on if adjacent wall leans in/out) at one end, leaving half the other end. This will then be reversed on next row (assuming you are doing brick bond) - you’ll just have to let the window happen!!
Reply to How to set out for an off centre window using bevelled metro tiles in the America Tile Forum area at TilersForums.com
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
  • Question
