Discuss Indian Sandstone Picture Framing/Grout marks in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Blunt Tool
Polythene and tape up aluminium rails, work in small areas 1 metre x 1 metre and adhere to instructions on bottle and it will turn out spot on how it should have looked. Only advice is the weather don’t do it early morning now for frost and try and get a 2 or 3 day good dry forecast
Also yes Lithofin cement away, a local tile shop probably stocks it
1sandyh
Thanks callatiler. If it splashes or flicks up will it burn through the polythene, on to the Ali track/glass? I’m so paranoid about ruining this. Same as how close it is to the new glass doors.
I’ll do a test area first too
Blunt Tool
No any splashes can be rinsed with clean water right away work methodically and you will see good results
Won’t burn thru polythenes it’s not sulphuric Or the stuff that comes out of aliens haha
1sandyh
Oh Jesus I’m going to be crapping myself doing this!
Just out of curiousity - what’s the difference between the lithofin cement away & the builders clean?
Should I use neat or ??
Blunt Tool
No use Lithofin and a 1 litre bottle can be diluted with 20 litres of clean water do not use neat. I would personally get a clean 10 litre bucket and add 100ml of cleaner and mix, then I would have 3 buckets of clean water beside me
CJ
Points
1,088
Somerset
I laid Indian sandstone in my back garden last year...........they definitely need sealing. Can’t remember what sealant I used, but the instructions said, it needed 5 clear dry days before sealing. Then I used Wickes own brush in pointing.......which was horrible stuff.......but it looked ok when done.
Bill
They were only meant to slightly wet the joints not the slabs, then brush in dry mix and leave for a while, then the dry mix sucks the water from the bottom of the joint then just smooth using a brick jointer and brush excess dry mix away. Now I would clean slabs with a cement film cleaner
Lithofin Cement Away (1L) - https://www.tilefixdirect.com/product/LFCA1L?gclid=EAIaIQobChMIp9iojo2-3gIVZpPtCh3oeAtdEAQYAiABEgJkxfD_BwE
Ultrascape is a wet grout and is supposed to go all over the slabs too. Other products differ.
Reply to Indian Sandstone Picture Framing/Grout marks in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
