Discuss Laying outdoor Porcelain 60cm x60cm in the America Tile Forum area at TilersForums.com.
Hello you Pro’s out there. I am embarking on replacing my current outdoor patio concrete slabs with Porcelain Slabs 60x60cm x 20mm
I have been advised to do it 2 different ways so far. Is there a Right Way and a Wrong Way ?
I have been advised to take up slabs, hardcore base, compact then lay concrete base on top, then lay using correct porcelain adhesive
Second person advised on after hardcore use a slurry base and set them on that.
which is Right/Best please.
all advice very much appreciated
Thanks regards David, in Birmingham
Reply to Laying outdoor Porcelain 60cm x60cm in the America Tile Forum area at TilersForums.com
  • Question
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
