Discuss Laying sandstone pavers outside in the America Tile Forum area at TilersForums.com.
First job with this type of stone (have laid floor and wall tiles several times successfully) Sandstone paving (B&Q bought says from India) 300x600 by 20mm thick. Laying on a solid concrete base - little uneven in places, but pretty decent. Small area - about 20 stones half of which will need 1/4 cut off (using angle grinder with appropriate disc)
Using an appropriate adhesive from Bal or Mapei (Mapei Keraquick Wall & Floor Rapid-Set Flexible Tile Adhesive White 20kg - https://www.NoLinksToThis/p/mapei-keraquick-wall-floor-rapid-set-flexible-tile-adhesive-white-20kg/7685v). So...questions.
Planning on using a 12mm trowel (achieve bed thickness of around 6mm). Adhesives I looked at are good to around 10mm thick. Is the trowel and bed thickness suggested appropriate? I considered a 20x10mm trowel.
Do I need to back butter the stones. I'm using rapid set adhesive and this will obviously slow me down if needed, however I will do if required. The back of the stones have little ridges along them (assume from engineering to get a uniform thickness). Not so easy to back butter because of it. If needed I will likely mix the adhesive in smaller quantities to allow time to butter. Will have them all cut and laid out ready to go before mixing.
So in summary - is the adhesive OK (their data sheets suggest they are) and is the trowel suggested ok? Back buttering or not?
I am very grateful for your time taken to answer my questions and put me at ease that I am on the right track or not as the case may be
Reply to Laying sandstone pavers outside in the America Tile Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
