Discuss New build bathroom floor in the America Tile Forum area at TilersForums.com.
Looking to get a bit of advice, tried searching through forums but there was no definitive answer.
What's the overall consensus on tiling a newbuild bathroom floor?
I am moving in next month which has Caberfloor P5 chipboard installed and wall tiles on one wall. ( attached picture if that helps)
From research I found that tiling direct onto the chipboard is a No No.
Instead it should be either:
1. Add 6mm backerboard glued and screwed to the chipboard then tile.
2. Add 12mm plywood glued and screwed then tile.
3. DITRA on chipboard then tile? (if the chipboard is solid with no vertical movement)
4. Rip up the chipboard and install 22mm marine ply then install.
For a DIY'er the range of answers make things slightly harder to decide...
Any advice would be much appreciated!
Paulg83
133
Glasgow
Hardie backer or no more ply boards on top of your subfloor is the way to go, gives you a solid base for your tiles
Reply to New build bathroom floor in the America Tile Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
  • Sticky
  • Question
