Discuss Polished Porcelain - Transit wax in the DIY Tiling Forum area at TilersForums.com.
Malcolm
I have (with a struggle) laid 600 x 600 infinity ivory polished porcelain tiles purchased from Wickes. Prior to sealing the tiles with the recommended LTP impregnating sealer, I was advised by Wickes and the manufacturer (Verona Stone Company) to remove the transit wax using LTP Grimex heavy duty grime remover.
I used this in a 1 to 5 mix with warm water, applying to the tile with a sponge, leaving for 5 mins and then agitating with a scrub pad and leaving for a further 20 mins ensuring the areas remained wet. I cleaned this off with a sponge mop and warm water, however, I am unsure whether this has had any effect and did not notice any transit wax coming off. I even used a squeegee and didn't notice anything. I have since buffed the floor and it looks clean and shiny but is there anyway to tell if I have removed the transit wax before I attempt to seal the tiles.
I have attached pictures of how the tiles currently look, although they do not look any different.
I would be grateful for any help or shared experiences. Many thanks.
It's very difficult to see transit wax in a photo.
It's generally very visible to the naked eye or touch. The tile can feel greasy.
Or it will appear smeared even after wiping with a cloth.
If there's a clean even shine to the face of the tile when polished, chances are it's gone.
One very simple way to remove it and be to get a handful of dry grout and rub it in to the face of the tile. The grout generally sticks to the wax and not to the clean parts. Just rub with your hands and it generally removes it.
Messy business tho.
Malcolm
Messy business tho.
Thanks for your response 3_fall, I'll give this a go this afternoon.
Reply to Polished Porcelain - Transit wax in the DIY Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
