Discuss Sliding Door Threshold to Tile in the America Tile Forum area at TilersForums.com.
ludapm
USA
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and replaced them with a sliding door. The frame is quite high so I'm going to do a transition that is not even. What is my best option to make this sound and visually appealing? I first thought about using a cut down wood reducer molding with silicone caulk between door frame and tile to allow for expansion. I'm now questioning this and maybe thinking just using a metal tile doing trim with the same silicone between this edge and the door frame. Again, the height difference between the door and finished floor is about 1.5" so its a step-over transition to the outside. What are your thoughts?
ludapm
USA
here is a pic of what I'm looking at and a possible solution.
Reply to Sliding Door Threshold to Tile in the America Tile Forum area at TilersForums.com
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
