Discuss Tiling part of a floor. in the America Tile Forum area at TilersForums.com.
Hi, I’m hoping someone could advise me. I’m wanting to tile only part of my garage floor. The back wall contains my utility but the rest of the garage is a gym so has rubber matting.
The garage floor is painted concrete. I know I have to put down some self levelling compound but how do I stop it spreading into the rest of the garage? I was thinking I could put a temporary baton threshold down and caulk or silicone the edge between the floor and the baton to stop the compound spilling out. Would this work? Also do I need to use uncoupling membrane over the self levelling compound? I’m getting mixed results on my research. Many thanks.
Kevbos
443
London, UK
Remove paint first
Reply to Tiling part of a floor. in the America Tile Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
