Discuss Victorian tiles hallway in the Canada Tile Advice area at TilersForums.com.
Hello,
am trying to complete a Victorian tiled hallway (pic attached), loads of questions to make sure I get it right.
I didn't hack through the floor to lay the pipework, previous owners did!
Floor is part solid, part suspended ceiling over cellar. New joists have been installed and are rock solid.
This is what I'm planning:
• make floor solid - done
  • pipes boxed in and boarded over (50mm marine grade ply, had it spare)
  • the remainder filled in with concrete
• now need to level floor - drops 2 inches
  • was planning to use Ultraplan Ren Screed
  • do I need to need a Mapei primer? (only looking at a 2sq metre area)
• lay anti-fracture membrane - am tight on height on one side of the floor, so no real space for a backer board
- any suggested brand?
• lay tiles
  • have already cleaned the loose tiles using brick acid - came up a treat!
  • using flexible adhesive (any in particular, any additives needed?)
• deep clean and seal tiles
- might hand over to an expert at that point
All guidance appreciated.
Cheers,
TN
107396
107397
Reply to Victorian tiles hallway in the Canada Tile Advice area at TilersForums.com
  • Question
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
