Discuss Show Us YOUR Work Thread - Tilers Pictures in the Tiling Work Showcase Forum area at TilersForums.com.
Status
Not open for further replies.
Spud
That is outstanding work as always Rainsco I love the steps
I have been doing some bathrooms with mitres recently but dont have the tooling you have
1200x 600 and 900 x 450 cut on site with a 115mm grinder and polished back with a hand polisher , filled one with resin the other with grout , just debating how to finish the last bathroom, how do you finish your mitres with glazed porcelain do you always sand back a 5mm bevel or do you sometimes keep them sharp?
20141111_174102 (1024x768).jpg 20141111_174113 (1024x768).jpg 20141111_174117 (1024x768).jpg 20141111_174120 (1024x768).jpg 20141114_162514 (1024x768).jpg 20141114_162524 (768x1024).jpg 20141111_182620 (768x1024).jpg 20141114_162543 (1024x768).jpg SAM_4611 (1024x683).jpg SAM_4623 (1024x683).jpg SAM_4612 (1024x683).jpg SAM_4610 (1024x683).jpg
R
rainsco
nice garry,
i don´t use the miller very often. i just use it when i have lot of stairsteps and can work at home. on site i use the wet cuter (for mitre) and sand the mitres exact with a 100 grid diamond dry pad to edge and then i use a aggressive 50 grid diamond dry pad to do the rest but not to close to the edge. if i don´t glue the mitres the tile is ok out of the wet cutter. if i glue the mitres i have to sand.
i try to get porcelain with a core in colour of the glaze. if its not, i say the customer just a normal groat mitre is possilbe or on stairs we have to work with rails.
here is a projekt with glazed porcelain. i mixed the glue from akepox grey/green with a white colour paste. the core of the tile is a little bit darker so i think i bevel it very sharp. bad08.jpg bad04.jpg bad05.jpg bad03.jpg bad02.jpg bad07.JPG bad01.jpg
when you look at the wet cutter. the table is more than 45 degrees. and then i sand it to edge with the grinders. its supersave and fast.
Spud
Love the work in that tray Gary !:hurray:
Whats happening with a screen? I usually get a standard wet room glass panel, sit it place, mark the bath edge with masking tape. Then, get the side that goes against the bath, either etched sand blasted or, a colour coded backing to match the tiles.
the glass is being sat on the bath and cut in around the panel ,the company will mitre the corner and bond the corner , I haven't seen their work but by all accounts they are one of the best around
Spud
Profilers...
I tried the profiling mitre wheel and it's too slow and you can damage the edge of the mitre , tried it a few ways,first I tried to use it on its own it just is too slow that way , they I hand cut the mitre with a grinder then used the profiler to finish it but want happy with the mitre on glazed porcelain as it left too much on the edge so I had to finish them off with the polisher
Status
Reply to Show Us YOUR Work Thread - Tilers Pictures in the Tiling Work Showcase Forum area at TilersForums.com
  • Locked
I spend some time in doorways. TJ's Doorway Mosaics for McKenzie Shop Front
  • Sticky
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread...
Join The Tile Association and Get Noticed Some time ago joining The Tile Association may have...
Morning all. Dan asked me to post up a thread about our training centre which he can then use...
