Discuss Correct Adhesive For Garage Floor Tiles in the Tile Adhesive / Grout Advice area at TilersForums.com.
Stef
From Ray's place, porcel-thin, about 6 hours are being tiled with TileMaster setaflex.
DarkSource
Thanks to all for your help!
However does anyone have an answer regarding an insulated garage floor? From the replies, I'm sure I can choose tiles and adhesive that will be strong enough if laid directly onto concrete, but I need a solution to insulate the floor as I want to use the garage all year round. I could use celotex and then put loads of screed over the top, but this would raise the floor by about 10-15 cm, which causes allsorts of other problems and isn't an option. From other forums people have suggested ditching the insulation and just using a space heater. This doesn't meet my requirements of a room that is easy to keep warm all year round i.e. well insulated with a couple of radiators. Surely someone has done this before? I can't believe I am the only person to have thought of this.
Kudos to the person who has a solution!
peteablard
1,058
Cheshire
I can't remember who it was made by(I will find out) but I used some insulation boards a few weeks ago that were far more sturdy than anything I've used before. It would be worth a phone call to the manufacturer to ask their opinion. I know cars are heavy but the weight is spread over four points of contact, each point approximately 25-30" square. I think it might work. You could always stick a couple of boards down,tile them and drive over them, park on them overnight etc.
DarkSource
Thanks Peteablard, fingers crossed that you can remember :). I know that (some) car dealerships have underfloor heating with tiles on the top, so they must have a solution that can deal with the loads (as you say about 6-700 kg per corner for a heavy 4x4).
DarkSource
If it's a 4x4 then the tyres are bigger so the point of contact is greater, in terms of point loading per square inch it's probably not much different to a smaller car with small tyres..... I think! A layer the of fibre reinforced SLC over the boards would help too.
I measured my car; the tyre patch is about 250x100mm (10x4") with a total weight of 1500kg. This gives just under 10kg per square inch. That doesn't sound excessive to me. Marmox is rated at 40 tonnes per m2, which is 26 kg per square inch. 10x4" could hardly be described as a point load?
What thickness of FRSLC would you recommend?
Ian
I've had a bit of a think about this and I'm confident it's possible. There isn't essentially going to be any point loading as it'll be spread over a 600x600mm (0.36 m2) tile. Now, marmox say their boards can cope with 40 tonnes per m2 so with a tile + adhesive ontop you'd have to have an immense amount of weight to get any compression. Even a 3000kg van is only 750kg at each corner which is well within the capabilities of the products and each tyre has a contact patch of around 200x200mm so, not exactly a stiletto!
It is maybe worth doing a test beforehand but, a 20mm board, then an S1 adhesive (tilemaster setaflex) or if you really want the belt and braces approach an S2 (tilemaster ultimate), then a grade 4/5 porcelain tile, would be my choice.
DarkSource
Thanks Bri - that really helps. Will start insulation and drywall in a month or so, so tiling is still a little way off, which gives me time to experiment.
K
Kevbos
Make sure you flat the back of each tile also to fill any frogs. Or undulations in tile this'll help strengthen the tile and relate a solid bed
Lou
Admin
1,473
Staffordshire
Reply to Correct Adhesive For Garage Floor Tiles in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
  • Question
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
