Discuss Deflection issue with No More Ply down in the DIY Tiling Forum area at TilersForums.com.
Deleted member 46792
Hello
I am a DIYer and after a successful shower tile project set about tiling bathroom floor. Victorian terraced house, previous floor - exposed original floorboards. After research and consultation with a carpenter, I understood that the deflection wasn't bad and that I should screw down any loose-ish floorboards and overboard with 6mm No More Ply using the NPM mega strength adhesive. Having done this and having been pretty pleased with my efforts I asked a tiler (and paid for consultation services) round to give me his opinion. He said that my floor has too much deflection and that the grout and possibly the tiles will crack. He gave me a couple of suggestions - the most expensive being to start again and lay down 18mm ply. This could be tricky as I understand that even in the event of a nuclear war the NMP will probably still be sticking to the floorboards because of the strength of the adhesive. The other option he said was to get some expensive adhesive - bal single part fastflex I think it was - which has an elastic ingredient and get flexible grout that you can add an additive to that will make the grout very flexible.
This evening I have been wondering if it isnt possible to double up with overboarding with a layer of ply or another layer of NMP. I also did a test that I have read about which involves filling a glass of water and placing in centre of room and getting biggest person you know to jump about a bit. Well I fit that profile so I have done that and no water was spilt. I can see some deflection in the floor but I am not sure what to think now. I am not sure what is acceptable, what remedial actions to take..
Anyone got any thoughts on this? I dont want to do a cr*p job but I dont want to pull the house down!
what size is the floor and what tiles are you wanting to fix?
Hi Julian, the room is 3m x 2.4m but there are bath, seperate shower tray and sink unit areas that wont be tiled. Its about 4.4 sq. metres of tiling. I have bought 60 x 30 porcelain tiles but they were cheap and would replace if something more suitable would go towards fixing the problem..?
I would be very surprised if a floor has that much movement and if it has is it going to hold a bath full of water!
@Kevbos wouldn't 12mm hardie board be better and no need for ditra.
Hi Julian, do you mean you doubt whether the deflection is significant? Would you agree with Kevbos that its probably an idea to add a further 12mm?
K
Kevbos
Yet I said put another 12mm of ply down preferably 18mm first to strengthen floor .I use ditra.to assure strength sticking to a solid wood floor .
And as your preferred method of fixing problem .yes the adhesive will stick tiles and not come up .but because adhesive so strong tiles will only just eventually crack as they the weakest now
Stef
He's already put down 6mm nmp, if the sub floor was prepped properly then I would have used 6mm Hardie backer & then tiled.
I don't tile to ply & wouldn't fit ply over the top to try & strengthen the floor.
I would rip it out & start again but an elastomeric addy takes up a lot of movement.
Controversial Kev is your new nick name.
I have over boarded many many bathroom floors with nmp and not had any problems. I would judge deflection with my eyes, if you can see any movement when your walking on it or lightly bouncing on it then it's probably not right, shouldn't see any movement. But if there is some movement it's only gonna be the joists.
Don't bother putting anything over the nmp it's a waste of time.
So I really have three options: 1) The correct way - rip up the NPM which will probably also destroy the floorboards. Fix/strengthen the joists so no deflection and lay 12/18mm ply floor, overboard with NPM or Hardiebacker. Tile. Expensive, disruptive and will make me cry.
2) The risky adhesive option - bearing in mind that the deflection is minimal a very flexible adhesive might resolve the problem. Only time will tell. 2 or 3 tiles would be affected. One commenter suggests he doesn't think i have a deflection problem in such a small room.
3) The raised floor option - Ply or hardiebacker. Adds 2 cm to the height of the floor. Will it definitely stop bounce after all that effort?
I hope the answer comes to me in the morning...night all. Thanks for weighing in.
Cheers for your reply...what do you suggest?
Reply to Deflection issue with No More Ply down in the DIY Tiling Forum area at TilersForums.com
  • Question
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some...
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
  • Question
