Discuss Purbeck stone grouting in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Hi all
I’m currently on a project using 20mm purbeck stone the field tiles are 435x435 with a 3mm joint.
the architect Has specified a lime mortar grout.
I have used a nhl-5 and sand mix to grout before as the floor was breathable the tiles had 6mm joints though.
This floor isn’t a lime screed so doesn’t need to be breathable.
I would much rather use a modern cement based grout so I’m going to try and convince the architect it’s the route to take.!
most architects I have come across live by their specifications so I’m guessing he will stick to his guns.
Has anyone else had success with a 3mm joint in lime mortar?
I’m really after as much info as possible - to either support my case for a modern grout or to reassure me his spec will be fine
Cheers
H
hmtiling
Hi all
Cheers
Is it a solid floor without ufh?
Boggs
1,118
Uk
I’m not sure if they can help in this situation but I spoke to a company called Stone Tech from Middlesbrough when I repointed a section of my house with lime mortar, they were very helpful.
Boggs
1,118
Uk
Couldn’t hurt to try them - cheers.!
Il probably just voice my opinion on an email then do as I’m told, at least il have a paper trail if anything should occur.
That’s the best way!
P
Paul H
Hi all
Cheers
Is it possible to get split face Purbeck stone at circa 20mm thick to clad external walls?
Lou
Admin
1,473
Staffordshire
Reply to Purbeck stone grouting in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
