Discuss DIY overlay boards for ufh in the DIY Tiling Forum area at TilersForums.com.
Hey guys.
Long time reader, first time poster.
I've got 42mm between my current concrete slab (insulated) and my desired final floor level (tiles)
How do I overlay my pipes?
Is there a thin screed that can be applied over the pipes?
Alternatively I was thinking of making some DIY overlay boards. I got the idea after reading about chipboard overlay boards and thought that I could make overlay boards out of plywood.
I would cut 18mm plywood in strips of 200mm and wedge the 16mm pipes in between each strip.
Each strip would be screwed into the concrete.
The plywood would then be primed and tiles laid directly onto the plywood.
The pipes would have plywood on both sides, concrete underneath and tiles directly above.
The total amount of space that needs underfloor heating and tiling is 4.5 sq m
Any advice would be much appreciated.
ES
Spare Tool
I would also bring to your attention of, who would the guarantee be with. What you are going to do is making up your own UFH system that does not have any testing results to back up its performance. Check with your chosen leveller manufacturer first but don't be surprised if you get a "No".
Is what it is though really Glynn...back in the real world we get advised by certain manufacturers to looselay 9mm ply over ufh or pour a cement based latex over aluminium foil, sometimes you just gotta do what you know works..
Thanks for the replys fellas
Very insightful.
3 maybe 4 bags of mapei renovation screed from Screwfix should do it..
This sounds like the best option to me.
So I can lay the pipes on top of the concrete and then poor the renovation screed directly above the pipes to the required level?
I have been recommended something like this too:
Concrete & Screed Fibres - 900G bag of 18mm polypropylene (PP) fibres 5060442883055 | eBay - https://www.ebay.co.uk/itm/Concrete-Screed-Fibres-900G-bag-of-18mm-polypropylene-PP-fibres-/141736144766
Does anybody have any experience with using Polypropylene fibres to make thin sand + cement screeds?
Thanks again
ES
you have to copy and paste the text into google mate. Its the first link.
Those ready boards are a good shout but it'll work out more expensive I think. I'll need 5 boards @ £25 each and levelling compound underneath them.
The Mapei looks good and it'll give better heat distribution.
I've already got lots of sand and cement and was wondering if I could make my own screed reinforced with PP fibre and SBR to fill 26mm worth of space.
Standard screed would definitely curl but I have heard good things about PP fibre.
Spare Tool
Very insightful.
Thanks again
ES
Ah I wrongly presumed your pipes were already fitted into pregrooved boards, like a polypipe type of system so the whole floor was already 16mm higher than the base, you need some sort of insulation under the pipes or you'll be wasting heat into the subfloor.. As it is it'd take a lot more than three of four bags of leveler, more like 10..
The concrete slab is already insulated underneath with 100mm PIR.
I was planning on putting overlay boards on top of the concrete and tiling directly on top of that. I was going to do DIY overlay boards, but now that I've realised I need to bring the floor up by 26mm, overlay boards won't cut it. Might as well reap the advantages of a screed. My calculations suggest I will need 6 bags of the Mapei screed :S
where are the pipes coming from? Please don't tell us from your radiator run
No, the pipes will be coming from a manifold although I have been given the option of a Danfoss TRV by my plumber. This basically feeds into the radiator flow. The idea is that because it is such a small space (4.1 sq m or ~30m pipe run) the boiler pump will be more than adequately be able to cope with it.
nah. It's not an actual radiator TRV.
It's something like this:
https://www.polypipe.com/housing/po...rlay™/polypipe-ufh-temperature-limiting-valve
That one is made by polyplumb specifically for underfloor heating, it only allows the maximum appropriate temperature for UFH. I hear the Danfoss ones are better because it measures all of the temperature inside of the valve and you dont need the probe.
Anyway, back to the topic.
Will the Mapei screed work?
Does anybody have any experience in making fibre reinforced screeds for thin (26mm) ufh screeds.
Thanks for all the help thus far.
ES
Spare Tool
I'm no plumber either but surely that valve doesn't reduce rad water temperature it just opens and closes letting bursts of pipping hot radiator temperature water through, its not actually regulating the water temp? @Wayne Brown
The Mapei Reno screed is perfect but I still think you require some insulation under the pipes, even if its just 6 or 10mm Jacoboard or similar..what you board with is saving on leveler so hardly a difference in cost..
Reply to DIY overlay boards for ufh in the DIY Tiling Forum area at TilersForums.com
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
  • Question
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
