Discuss Wet UFH & Quartz White Mirror - All Installed in the Tiling on Underfloor Heating area at TilersForums.com.
Hi everyone,
With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a local supplier.
We then opted to have a wet UFH system installed into the existing concrete floor, with channel grinded out and pipes laid, a manifold was installed with thermostats for the 2 rooms.
Knee deep, when the tiler turned up he mentioned of issues with UFH and quartz, at this point there was no turning back. But I took some steps to help minimize an issue.
We used TP's Excel Bond Super-Flex S2 adhesive, tiler was shocked at the price I paid and said he would only use bags half the cost.
We allowed the adhesive and tiles to set for 4 weeks, and couple days ago, I started the commissioning process, starting at 20c at the manifold TRV.
24 hours later turned this 25c, 36 hours later upped it to 30c.
Now I'm planning to decrease it over same period back to 20c, and found between 25-30c provides the warmth we wanted.
Is there anyone other thing we should be doing to minimize the risk to the quartz tiles from the UFH?
I don't plan ever going to above 30c at the manifold.
Thanks in advance!
Tile Marble Granite
Time only tells. I thought the quarts will bend from heath. Hope yours will not. Quartz comes in different qualities. Find out what category quartz you purchased from the store. Usually stores sells good stuff.
Quartz is man-made in factory tile, the quartz resin mixture is as follows: 30% resin to 70% quartz, 50% 50% and 70% 30%. The last one is the worst quality.
About 10 years back I've done a small bathroom floor quartz job for a friend of mine, he bought the tiles dirt cheap online. I had a feeling its the cheap quartz he got. Overnight the entire floor, every single tile curved up from moist/heath.
Dan
Admin
5,039
1,323
Staffordshire, UK
Hi everyone,
Thanks in advance!
Are you in Astralia or UK matey?
About 10 years back I've done a small bathroom floor quartz job for a friend of mine, he bought the tiles dirt cheap online. I had a feeling its the cheap quartz he got. Overnight the entire floor, every single tile curved up from moist.
Thanks, I'll find out from the store, it's not a national chain but a family run tiles shop.
When the tiler expressed his concerns I rang the shop and the owner said nothing to worry about and he's had a few customers install with UFH with no issues as long as the right adhesive is used and time is allowed for it to cure.
Reply to Wet UFH & Quartz White Mirror - All Installed in the Tiling on Underfloor Heating area at TilersForums.com
