Discuss Tiling a wall that isn’t flat. in the UK Tiling Forum area at TilersForums.com.
61
Midlands
Hi, first time posting.
I’m in the middle of tiling my own bathroom, first time having a go at it. After doing a half wall and the first wall of the corner shower I’ve made a few mistakes but figured it out as I’ve gone.
Before starting the other shower wall I thought best to check the wall flatness first, in hindsight it’s obvious I should have done this prior to tanking.
The first 600-900mm from tray up has a dip in the centre of the wall, starting at 5mm in the centre and running out to flat as you go up the wall.
Would it be best to flatten this out with a feather edge before carrying on or have a go at applying more adhesive to the back of the tile where needed as I go? Bearing in mind I’m a novice. Using 300x600 tile with a 10mm notched trowel.
Any advice would be appreciated, thanks :)
Photos don’t really show it very well but I’ve attached some anyway.
Tile Marble Granite
758
Brownstown, MI. USA
Yes, you need to prep the walls prior to tiling, that's how it is done. Send us some more pictures once you are done. Good luck!
Dave
Subscribed
1,000,000
Co.Durham
Photos don’t really show it very well but I’ve attached some anyway.a was
Yes just feather the wall in with adhesive.
Myrdaal
83
manchester
Exactly right, 10mm adhesive trowel on the wall over the dip, also trowel some on the back of the tile to build it out a bit. You can use tile levelling wedges ( or those orange screw type levellers) to help keep it flat( and of course use a spirit level). Push the tile(s) in well at the edges. You may have to reduce to an 8mm (try not to go to a 6mm for that size). Make sure to butter the back of the tiles.
223
Bucks
as someone who tiles day in day out seen the worst walls and the flattest walls. in my opinion as tiling is the finish product it’s better spending more time getting everything flat so it’s just trowel and stick I do so much work for people who don’t understand how a bent or bowed wall effects costs and time and finish. In the real world every wall should be level top to bottom but the majority of the time that isn’t possible tilers wants flatness. If there’s any bows now or bumps in any wall the cheapest way is too buy a bag of bonding use a straight edge and build the wall out flat. Tile adhesive is expensive and bonding is cheap I say that’s the best option from many experiences packing tiles out always ends up in a mess and stress.
223
Bucks
Nothing is 100% level especially in old houses but being flat with your tiles is so important on certain walls likes windows where trim is needed and where shower doors are going get it 100% flat before any tiles go on the wall and it will make it 10X easier!!!
AliGage
Subscribed
1,138
Peterborough, England
5mm isn't much to sort out. As some have said here, bring the wall flat with some rapid set adhesive.
Probably advisable to use something more reliable to be straight and true than an off cut of ply though!
423
Huddersfield
Fail to prepare, prepare to fail.
All the walls need to be + or - 4mm over a 2m length.
You’ll struggle if these Building Regulations for tiling are not met.
Dan
Admin
1,318
Staffordshire, UK
As above you might get away with it, do a row at a time from what's straight and get a level! And use that to keep your rows as straight as they can be.
Reply to Tiling a wall that isn’t flat. in the UK Tiling Forum area at TilersForums.com
  • Sticky
