Discuss 1930s bathroom tiles just discovered! But how on earth do I go about restoring them? in the Tile Cleaning and Restoration Forum area at TilersForums.com.
H
HMVR
Yesterday we pulled off some blown 70s/80s tiles from our bathroom wall in our new house and were very excited to find the original green 30s tiles underneath. I would love to keep them but have no idea where to start. The main problem is that they are covered in tile adhesive. What is the best way to remove this? Thank you.
F
Flintstone
I would be very supprised if they were all in tact and none had been chopped to accommodate a change in pipe work or bathroom fittings, I would try removing all the top layer and see what you have first then
H
HMVR
Hot water, lots of it, will usually soften the old acrylic adhesive. Combine with a scrubbing brush.
Brilliant, thank you. I'll try that. Sounds more doable than some of the things I thought we might run into - like acid...
H
HMVR
Yes, I wonder if we might have to reuse them in some way rather than keep them where they are.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Behind them might be laths rather than brick or render. Might struggle to get them off without bringing pars of the wall with them if that's the case.
Points
268
Wiltshire
Never know it they will come off whole though for re-use! Good luck. Hot water and a strong arm but try and clean an area which looks "damaged" or "imperfect" underneath would be horrible to do all that work for nothing if you end up tiling over it!
Lithofin BOB
Points
508
Hampshire
Could also Use white or green pads to aid removal with your hot water, if you need an acidic based product if stubborn and they are ceramic , use a specific tile grout remover , not hydro - brick acid
N
NZ_Tiler
Depends what the adhesive is. If it's an organic type adhesive and none of the above work, try some acetone.
Make sure you have plenty of ventilation...
Reply to 1930s bathroom tiles just discovered! But how on earth do I go about restoring them? in the Tile Cleaning and Restoration Forum area at TilersForums.com
