redchair
Moved this as I incorrectly posted in the Pro forum!
Hi all,
3. What size trowel? I've got an 8x8 and 10x10, surely anything more is overkill for the size of tile?
All the best and thanks in advance.
Hi all,
Finally getting to lay the tiles in our renovated kitchen tomorrow, its been slow going but the end is in sight! Tiles are 200x200x9 porcelain Floor will be levelled with Ardex NA. Thinking A77 for adhesive and wanted to get you guys advice as to whether I
1. Should use a decoupling membrane? No issue buying, but want to make sure it’s worthwhile? We live in an old Victorian terrace which is prone to movement through the seasons (no idea if that effects the kitchen concrete!)
2. Any advice on laying the SLC, it'll be 6 bags and my first time! Do I need the floor to just be 'flat' or absolutely level? Should I mix all bags at the same time, or just good prep and work as I go?
Hope you can help, the fun starts tomorrow..
